Bose Companion 3 Computer Speakers Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound but not audible coming from speakers.
Speaker volume don't work. Maybe less than 10% volume coming from speakers. I have increased the volume in all of my settings, nothing helps. When I set on digital..there is absolutely no sound.
  • djhof
    djhof Dec 29, 2013
    I had this same problem...sound was very faint from the speakers and the light on the control pod was dim. I saw other postings about a faulty transistor on the amp/EQ board. This transistor is a small rectangular surface mount component that is located above the capacitor marked C313. By luck, I had a 2N3904 from a SparkFun kit, and I matched the B, C and E legs of the 2N3904 to the Base, Collector and Emitter pads of the surface mount transistor (this while the unit was powered up - not easy to do with the wiring in that bass box!). All I had to do was touch the correct leads to the board and the light on the control pod came back on full strength. Just to be sure, I connected my computer to the input on the bass box and played a few songs. Success! I did not solder the 2N3904 to the board at all - just touching the leads for that instant seemed to do the trick. It has held for a few days so I screwed everything back together again. We'll see how long this lasts!
Ginko
Level 3:
  • Bose Master 19,396 Answers
  • Posted on May 01, 2009
Ginko
Bose Master
Level 3:
Answers
19396
Questions
25
Helped
8074827
Points
55462
If the problem does not depend from the source, then that sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
How do i fix low volume on pc
No singular answer. Here are some of the things to try, following by links depicting details: 1) Update audio drivers via device manager or 3rd party ware 2) Change sound quality by altering Speaker properties via Sound icon on task bar 3) Change Loudness Equalization of Speakers in Enhancement tab of Speaker Properties 4) Run Audio Troubleshooter 5) Use Windows Volume Mixer to increase sound 6) In Sound, change Communications tab to Do Nothing 7) Try different audio device 8) Try VLC and adjust it to boost volume 9) In Chrome, use Volume Boosting extension 10) Clean speakers 11) Increase Media Player sound
https://www.minitool.com/news/fix-windows-10-volume-too-low.html
https://www.makeuseof.com/ways-to-fix-low-volume-windows-10/
https://www.thewindowsclub.com/computer-volume-low-windows
2helpful
How do i connect speakers to PC ?
If you have WS media player its automatic once you connect the speaker jack into the audio hole...dont forget to check if your speakers require power, plug them and increase the volume to an audible level.
If after all above has been done and no sound go to: Control Panel+ sound+ sound and click the drop down so you are able to change the option to windows default...click ok and apply. Then close and re open windows o play sound.
How to increase speaker volume
Use VLC media player to play videos. It supports almost all format and plays videos smoothly. It can increase your sound to upto 400% . but be careful. Use full volume only when the sound is less or the speaker may get damaged.
How to increase the volume?
use VLC media player to play videos. It supports almost all format and plays videos smoothly. It can increase your sound to upto 400% . but be careful. Use full volume only when the sound is less or the speaker may get damaged.
I have my laptop hooked up to the z506 surround sound speaker system. Since I don't have a good sound card or multiple ports to support 5.1 surround sound, the rear speakers do produce a bit of a...
Check that your mic settings in the Volume control is not maxed out. Turn the mic off and see if the fuzziness clears up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Re Sony VAIO F12 (new unit): Audio is barely audible using onboard and external speakers, even though volume bar indicates volume is at highest level. Any way to increase audio volume? Thanks.
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
2answers
I have a Philips home theater HTS9810 and the problem facing me is that the wirless rear speakers are pairing with the subwoofer but still no sound coming out from it. even if i do the speakers sound test...
If the pairing is successful with blue light in "on" condition and there is an audible cracking noise when the volume is increased, then the amplifier board (part no. 313924714051) of rear speaker has to be replaced.
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
1helpful
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
