Sounds like your battery is toast, buy a new one from nintendo, or ebay.
Did you attatchthe charge cord into the back of the Ds and attatch it to the wall? If you did and it didnt work, then I suggest getting it looked at, as this is usually the less expensive way of fixing it.
Make sure you check the compatibility of your
charger check the back and below the DS game
card slot you will see numbers with a point in the
middle equals in. For example if the label of your
charger says 5.2V and if the writing says 5.2V
that means its compatible.
Make sure your charger is not broken and your wire for your charger is not old are ripped up, the best thing would be to buy a new charger, i recommend BEST BUY
Your charger is broken.
For example, if you have a 110v charger and use it on a 220v outlet, it will burn out.
You can get a new charger, or buy a Car Charger.
Car chargers work with both 110v and 220v, but you need a car :/
