A FEW MONTHS AGO, THE WASH BASIN FILLED UP QUICKLY. NOW, THE WATER SEEMS TO BE OBSTRUCTED AND ''DRIPS'' INTO THE TUB.
THE WATER COMING OUT OF THE HOSES IS FINE.
I HAVE DISCONNTED THE HOSES. HOW CAN I GET TO THE INTAKE SCREEN, IF THAT IS THE PROBLEM?
Once hose is off water valve take a small flat head screw driver and pull screens out.you will see if they are clogged once they are out.
what brand is your washer and i will tell you how to get to it and remove it.
take the 2 screws out of the face of machine one on each side,lift face up,you will unplug lidswitch from cabinet and you will see 2 gold clamps on each side.take screw driver(flat head)and pop out gold clamps.your cabinet to the machine will come off then.you just pull forward and lift up and it will come off.you will see water valve on back right side.take screws out of water valve and take hose on inside of machine off that is connected to bottom of water valve and your wires to the valve and it is done.good luck and if you run across anything that doesnt look right then write back and i will walk you thru it.
hesitant to force out screens. have read that they can be popped out, and that they cannot. mine do not appear to pop out easily. with intense light, the screens still appear clean. i think the buildup is inside/ past the screens.looking to replace inlet valve. i just need to find easiest access, remove control panel?
kenmore
