Im trying to figure out if my car needs new braking fluid, new rotor, or something with the tires. I hear a loud humming noise after passing 30 mph and it only gets louder as I go on. besides the noise the car runs fine. shifts on time. it breaks perfectly, makes good turns and it doesn't smell like burning. I have no clue what it could be
SOURCE: loud humming noise from front end of Durango 4 x 4
You have a hub/wheel bearing going out. You need to jack up the vehicle on each side. Grab the top and bottom of the wheel and try to move it in/out at the top and bottom. If this does not work then roll the wheel as fast as you can and see if you can hear which one it is. Good Luck.
SOURCE: Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
SOURCE: dodge stratus making humming noise coming from
Have you right hub bearing checked ,This is a common problem on these stratus models :)
Testimonial: "thanks, thats what I was leaning towards"
SOURCE: the engine is making a really loud knocking noise
Doesn't sound good. Check oil level. Also check for metal in the oil once you pull the dipstick. A loud knocking noise is a sign of a blown engine may be you spun a rod in which case you would need engine replacement or rebuild
SOURCE: My front end is making very loud noises every time
same thing thats wrong wth mine ur bushings r bad. replace ur upper and lower ball joint and dont no proper name 4 it but outer tie rod goes to bushing on wheel change it.thats what im trying to figure out how to change.good luck
Testimonial: "thank u so much it was very helpful. i almost gave up hope for awhile"
