AOSmith Pump USQ1102 - won't start, no sound, nothing...was wondering before I called a service, is there a reset button or something I could try myself?
Hi, this could be one of a couple of things, firstly check the pump is plugged in securly to the main panel, secondly, check the fuse inside the panel hasn't blown, third, there is a capacitor inside the connection box of the pump (where the mains lead goes in), this sometimes fails causing the pump to stop working, this should be replaced like for like. Good luck!!
Thanks so much, I will try it this afternnoon! But I did find out that the pump is separate from the motor and someone told me it might be the motor and would cost hundreds of dolllars. So I am hoping this advice is the problem. Thanks again
