I hooked up DVD player to TV (double checked to make sure correct).
I am supposed to see a blank blue screen, but I don't. DVD Player is running after I put a DVD in because the numbers are changing on the display, but nothing on my TV screen.
On some sets there is a button on your remote marked "TV/VIDEO" or some such text. With your tv and player hooked up and working, pushing that button will switch from TV to video and back.
On other sets, if you keep changing channels, you will eventually come to one that turns off the video broadcast and plays the DV.
Good Luck
You need to supply more info to get a correct answer.
How is it hooked up to the TV? Composite video ( yellow jack ) or Component Video ( green blue and red jacks)?
You may need to set the DVD player to Interlaced Scan if you used the yellow jack or Progressive Scan if you used green red and blue.
If you used Component ( green blue and red) check your tv specs to see what resolutions it supports on it's Component Input.
When you change the TV to what ever input you used, do you see anything?
