I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black! what should I do? please help me....
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale
shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale
black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally,
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Testimonial: "Sorry if it was ambiguous, Laptop LCD is black but is on, 2 or three times after 30 minutes Laptop LCD became on suddenly and works for a long time, but next day again it has the problem, external monitor always works... it has no problem...."
SOURCE: LCD laptop screen
It is definitely the screen or the inverter. Usually the screen and inverter come as one piece. I would check with the manufacturer. Unfortunately for you, the LCD is one of the most expensive parts to replace on a laptop.
Just the simple fact of you mentioning that it works fine with an external monitor tells me that its not the video card. If it was the video card, you would see the exact same thing happening on your external monitor as well.
Hope this helps!
SOURCE: DELL inspiron 6400 laptop screen turned black
this sounds like a classic case of inverter problems, it could be just inverter coil thats gone which is an inexpensive repair, if it is the inverter then its a bit more.
try the Fn the F key that shows two tv screen icons, it may just have switched to external mode by accident
good luck
SOURCE: The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
SOURCE: monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
SOURCE: Sony VAIO VGN-NS10E - Booting Problem
Hi!
Yepp, its easy to solve that problem. Get in the bios and change the boot up seqvence, ist probly set to look for all kinds of bootble divices, change that to only boot from the hdd in your laptop, disable all other boot devices, when you done that, hit F10 to save the settings and restart your laptop.
Good luck
Nic
