NEC DTU 8D-2 Corded Phone Logo
Posted on Mar 13, 2009
Turn the ringer on for external calls.
The phone ringers for internal calls but will not ringer for incoming exturnal calls. How do I turn that ringer on?
Anonymous
Level 1:
  • Contributor 63 Answers
  • Posted on Mar 14, 2009
Anonymous
Contributor
Level 1:
Answers
63
Questions
Helped
42208
Points
91
In system programming
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
Ringer is off/cannnot hear incoming calls - instructions does not include how to turn the ringer back on
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish.
that will make your phone ringer work as expected and supposed.
wish you good luck,
take care.
Aug 13, 2010 • Cell Phones
2helpful
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
2answers
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
Simply want to turn ringer off at my phone for external incoming calls
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
