I speant Hours swearing at my phone because it would not read my music
files, Tried the card on many different phones which would take Micro SD
and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
I found that using the phone's USB connection in data storage mode and using the 'copy' function instead of 'send to' to transfer music from my computer worked. This took some trial and error (lots of error) and swearing at the phone!
I have read elsewhere that putting a new file called 'MP3' in the sounds folder also helps.
Andy B
Kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
It seems that althought the phone will read photo files even if they are not in a folder it won't read mp3 files unless they are. Once music files are added to the memory card in a folder, the phone will read them. Still don't have all the options available on LG PC suite though but thanks for the advice.
