go to google then in the URL box not search type in the ip address of the copier will get the copiers web page. log in as administrator theres a tab for network then select scan to email smtp info goes there
some wireless routers do not allow printing or file sharing check your router specs and settings. also if the wireless router has encryption turned on the bizhub will not print thru the router because the bizhub cannot be set to use a ssid and key code to access the router
The scan-to-email may have been set up originally to utilize the old email server, using the old domain as the conduit for sending the scans through your network.
You may have to load the driver onto the new email server, or the main network server itself (which would then allow you to scan to emails with any destination as it is using the networks connectivity to deliver the emails, not the email server).
Then you can set up as many new user accounts as you want.
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
If you are just adding your PC to the network first go to control panel click network set-up wizard. to add your PC to print add printer from the control panel and look for the network printer. last you want to scan go the internet web browser input the ip address of the scanner or copier click public or administrator enter password 12345678 and click scan tab and add your PC host name or your email address if scan to email.
with scan to Email on this machine you need a mail server that is local
with ftp scanning you need IIS running on either XP Pro or server OS
SMB Scanning can be done but only if you are using an eithernet connection
which one of these do you want do to do
