Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Hi onestoppa972, I could try and explain it to you, but I think it would be better for you if you were to read it and have the pictures for reference. If you don't have the manual, you can download it here: http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/A500-_E Just follow the instructions and download it for free and it shows the various flash settings. If I can help you further, please let me know. Thanks.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
I assume you mean the card protection on the SD card??? Turn off the camera, pop out the SD card, slide the little switch on the side of the SD card from locked to unlocked, re-insert the card the way it came out, and turn the camera back on. If it still doesn't work, take thed batteries out, reinsert them, then turn it on again. It should be ready now to record onto the external memory. If it still doesn't, get the manual out and check on transferring fiels from internal to external memory.
In photo editing programs there are Hue settings where you can easily fix that problem. There are off course night lens filters but not for amateur cameras.
