SOURCE: The router bits will not fit in the collet.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
SOURCE: Back in December 2009, I wrote asking why my Freud
Thanks for the follow up....
I'm glad your problem was resolved in the end.
