I have CRW8424 internal burner. When I try to write any CD it gives me "Track Following Error" and my CD goes waste.
Can u please let me know what could be the problem with my burner...below is the error log produced by Nero after error,
------------------- Log Starts --------------------------
AK
K
1A23-2045-8001-7268-4102-1210
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 3:25:04 PM
Nero version: 6.0.0.11 (Nero Express)
Recorder: Version: 1.0j - HA 1 TA 0 - 6.0.0.11
Adapter driver: HA 1
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: Version: 3.0A - HA 1 TA 1 - 6.0.0.11
=== Scsi-Device-Map ===
DiskPeripheral : ST310212A atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST320423A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : YAMAHA CRW8424E atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : TEAC CD-540E atapi Port 1 ID 1 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 209MB (214344kB)
Memory in use : 59 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
5.8.2007
CD Image
1:10:39 PM #1 Text 0 File Reader.cpp, Line 118
Reader running
1:10:39 PM #2 Text 0 File Writer.cpp, Line 127
Writer YAMAHA CRW8424E running
1:10:39 PM #3 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-at-once, using CD-R/RW media
1:10:40 PM #4 Text 0 File DlgWaitCD.cpp, Line 228
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 208155 (46:17.30)
1:10:40 PM #5 Text 0 File DlgWaitCD.cpp, Line 233
Write in overburning mode: FALSE
1:10:40 PM #6 Text 0 File DlgWaitCD.cpp, Line 1722
Recorder: YAMAHA CRW8424E;
CDR code: 00 97 15 37; OSJ entry from: NAN-YA Plastics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 0F 25 (LI 97:15.37), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
1:10:40 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 768
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CD-ROM Mode 1, Joliet)
2 indices, index0 (150) not provided
original disc pos #0 + 208156 (208156) = #208156/46:15.31
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 208156 blocks [YAMAHA CRW8424E ]
1:10:40 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 937
Prepare recorder [YAMAHA CRW8424E ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 426610688, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
208156 | lead-out | 1 | 0x00 | 0x41
1:10:40 PM #9 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
1:10:40 PM #10 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
1:10:40 PM #11 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 4x (600 KB/s)
1:10:40 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 2130
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
1:10:40 PM #13 Text 0 File Mmc.cpp, Line 14422
StartDAO : CD-Text - Off
1:10:40 PM #14 Text 0 File Mmc.cpp, Line 14720
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 2e 11 1f
1:11:06 PM #15 SCSI -1119 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04240000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x82 0xEC 0x99 0xED 0x0A
0x00 0x00 0x00 0x00 0x09 0x00
1:11:06 PM #16 CDR -1119 File Writer.cpp, Line 335
Track following error
1:11:07 PM #17 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
1:11:07 PM #18 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
1:11:07 PM #19 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
1:11:07 PM #20 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 4x (600 KB/s)
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=8.0.0.212 , size=2432 bytes, created 10/5/2006 8:12:44 AM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 10/5/2006 8:12:44 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 4/23/2007 5:45:26 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/18/2003 12:00:00 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
--------------------Log Ends here --------------------------
Thanks in advance.
Regards
Amod
Hi Biba,
Thnks a ton. My problem got resolved based on your suggestions.
I replaced my SMPS for testing purpose with new one which has higher Power output.
After that I burned 15 CDs with different brands including CDWRs and neither of them failed.
Thanks a TON!!!! I saved a lot of bucks on new drive price.
Warm Regards
Amod
