A xx1 cassette is removed in exactly the same way as a normal cassette
Using a normal lockring tool.
Consider the following tech bulletin:
https://www.google.com/search?q=xx1+cassette+removal&oq=xx1+cassette+removal&aqs=chrome.0.69i57j69i60.4446j0&sourceid=chrome&ie=UTF-8#fp=9a975e048e4bd6d6&q=xx1+cassette+removal&start=10
The "locking tube" is not fully self extracting, but can be self destructive. Use the screwdriver to disengage the cassette from the driver, after loosening the locking tube.
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
