The auto program tuning places channels with the clearest picture at channel 12,13,14 etc. Don't have the user guide & want to know how to set them manually to be on channel 1,2,3 etc. Thanks :)
Not connected to Cable TV, just after the regular free-to-air Australian channels..Not connected to Cable TV, just after the regular free-to-air Australian channels..
You can't post conmments that contain an email address.
It sets the channel according to the frequency they are on, If you don't have any channels below those numbers and are connected to Cable TV, you have a bad tuner
They asked how to manually tune the TV. It's got nothing to do with cable TV and the tuner is not faulty.They asked how to manually tune the TV. It's got nothing to do with cable TV and the tuner is not faulty.
hi,
To Re- tune your TV you have to go to the Auto tuning option in the
menu. do the following procedure for auto scan all the available
channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote. 2. Select Auto tuning and press enter. 3.Select the country and press enter. 4. Select start and press enter. The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear. If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB. ok .
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound. You can go into manual tuning and store it.
TUNING
This DVD+VCR is equipped with a frequency synthe-
sized tuner capable of receiving up to 181 channels.
These include VHF channels 2-13, UHF channels
14-69 and CATV channels 1-125.
Auto Channel Programming
1. Choose the SOURCE SELECT option, then use
b / B to select TUNER.
Use b / B to switch among TUNER, LINE1, and LINE2.
2. Choose the AUTO CHANNEL SET option, then
use b / B to find channels.
• The tuner will automatically cycle through all available
channels (TV/CATV) in the area and place them in
the tuner's memory.
•After the AUTO CHANNEL SET is complete, the
TUNING menu will hide and return to the TV screen
automatically.
3. Make sure the TUNING BAND is set appropriately
(TV or CATV).
• TV : If you are using a standard antenna to receive
channels.
•CATV : If you are using basic cable to receive
channels.
Most of the sony TV's comes with an auto tuning facility and all your need is ensure that the RF inout/cable TV or antennae is plugged into before the auto tuning is activated.
The auto tuning is available inthe older models on the set and in the newer models on the remote control. Choose program menu , tuning, auto mode.
Also you can search inthe manual mode individually and preset the channels position to your convenience such as news channels together, movies together etc.
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto Channel Search Auto Cable/Air Switch sets tuner to cable or “off-air” frequencies during initial setup. Then system automatically scans for and locks active channels into channel memory.
