I have a Mitsubishi Model # WS 65311 HD 1080, it turns on and then after about 2 seconds it shuts off. Like its popping a circuit breaker.
Try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
The 24 code means vertical deflection failure the most probable cause is IC4B01 which is a TDA 8177 you can get a replacement at the following link. http://servicemanuals.vstore.ca/product_...
Heres where its located within your TV note the red circle.
send me a email to [email protected] and I can email you the diagram
the blinks were 22.
THE BLINKS ARE ACTUALLY 24...SORRY
can i get a diagram that is easier to read? thanks for your help too.
My Mitsubishi Model # WS 65809 is doing the same thing. When I turn it on it stays on for 2 seconds and shuts right back off. Is the solution and part number the same as the WS 65311? Any help is GREATLY appreciated. Thank you!!!
I need to view a live picture of circuit board so i can replace the power supply
