I use this for a business and have noticed ever since I changed to a new transfer ribbon, the bar codes print too dark, so much so that the bar code lines run together and the barcode will not scan. I have tried to adjust the printhead darkness which is set at 25.0, down then tell it to permanently change, but every time it prints a bar code, it resets to the 25.0 setting. How can I solve this problem?
SOURCE: I have a Zebra s600 that is set to 30 darkness and
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
SOURCE: I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
SOURCE: I am printing bar codes. In the bar code it is
In the software provided adjust temperature setting of print head before printing the job. Please also check for bad ribbon. Please don't hesitate to ask if any further assistance is needed. Good Luck
SOURCE: z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
