Suggest you check all your terminal connections for corrosion. I just had exactly the same problem with a Xantrex inverter/charger, it appeared to be stuck in charge mode. I disconnected all terminals, cleaned them and in the process found two with corossion not visable before disconnection. Problem solved
Don
More than likely you may a a relay that is stuck or not energizing which should switch the charging mode over automatically. Trace back from the generator to the charging circuit for the batteries. I'm not sure where the relay (or solinoid) would be located but you can be assured it is something in the charger sensing/switching circuit.
Good Luck! Gary
