I've connected my 803 to my sharp LCD via HDMI, and my comcast hd cable box and my dvd player to the 803 receiver via HDMI; but i can't hear any sound on TV? I have not yet connected my surround speakers... the message keeps stating that the "...input device is not proper..." Please help.
I have my Directv receiver connected to my Sharp Aquos LCD via HDMI. The TV wont send the audio out as Dolby Digital. When I connect my Directv receiver directly to my audio reciever Dolby Digital decodes fine. I would like to have all audio going through the TV so I dont have to switch audio cables each time I switch devices. Also i need the audio coming from the TV to listen to the TV tuner through my audio receiver.
SOURCE: Sharp Aquos speaker buzzes
In my opinion i think that the your television is messed up. so you should either return it or keep it. I had this same problem but i tried everything to fix it but i couldnt so the best is just to return it
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
