I've tried to reset my nano multiple times and there is no response. I have also tried resetting it to the default settings which has also had no luck. Basically the lock symbol is on, as if I had the re-set switch on, (pushed over to the right), but it isn't. Since the lock appears on my screen I can't turn my ipod off, or do anything else, so it won't hold a charge. I had only been using it for about a month. Please help!
SOURCE: Ipod Nano can't unlock volume lock
First make sure your hold switch isn't on. It's on the top or bottom and slides
back and forth. It needs to be switched to the left. Once it is to the
left, here's how you reset:
You can reset your ipod by holding down the menu and select (round
button in the center) buttons down for at least 10 seconds. You'll see
an apple logo flash, that's when you stop pressing the buttons. It will
shut off, then back on.
If that doesn't work, try a restore. This will return it go factory settings.
How to restore iPod
Heres how
http://www.fixya.com/support/r538899-unlock_ipod_volume_control
Remember to rate my solution as fixya, becouse I know this will fix your problem as it has for many others before you!
From my experience with iPods, the only way to get rid of lock codes that you can't remember is to do a restore on your iPod. This will result in all data being removed from it however. But if you have a backup on your computer of everything you have, then you should be fine. You will have to reload all your music and stuff.
Heres how to unlock the volume control.
Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
