2006 strider mobility scooter, was working all fine until got stuck on some gravel, slight wheel spin, now no drive and green dash light flashing twice,then space,then twice etc, Any ideas ? Thanks
For home use and commercial use. Design by you built by us...
Lighting
2 = A fault code of "2" means the battery voltage is too high (there
should not be more than 28 volts running through the chair).
Check that the proper charger has been used on the batteries
(remember that eventually, batteries do come to a lifespan end and must
be replaced).
Brakes/Controller
www.axess2.co.uk/products/platform-lifts/
Motor
Other
4 = The fault is in the right motor. Resistance for the motor contacts must be higher than 1 MEG Ohm.
7 = The fault is in the joystick. The joystick must be released and
in the neutral position on when you turn on the chair. If not, it may
signal a fault.
Read more: List of Power Chair Fault Codes ' eHow.com http://www.ehow.com/list_5877325_list-power-chair-fault-codes.html#ixzz1qA7wfajQ
Switch ignition on green light flashes no drive
the yellow light flashes twice and the brakes are stuck
