My fisher & paykel gw612 top loader 'sounds like' it's trying to drain constantly. If the power is switched on at the wall its trying to drain - even if I haven't turned it on using the power button on the control panel.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
SOURCE: Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
SOURCE: Fisher and Paykel GW612 - Lights showing
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
SOURCE: My Model GW712 won't spin or drain Top loader
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Worth mentioning that the machine is still operational - apart from the drain pump noise (if thats what it is) I can select a cycle as normal and start it. I have not tried running it through a full cycle though.. it just appears it would work. I'm more than willing to pay for a solution (I thought you used to pay for solutions on this site?!)
This has been answered on justanswer.com - ended up needing to replace the controller board.
