Do you know where the satellite module is located in this car?
Power down your Toshiba Satellite.
Unplug it from the wall.
Turn the machine over and remove the battery.
Locate the RAM compartment cover, which is usually located somewhere in the middle of the underside, and is about 4-by-4 inches.
Unscrew the RAM cover screw with a Phillips screwdriver and set aside.
Ground yourself by touching a metal object.
This will release any static electricity built up in your body, which can harm computer chips and components.
You can also use an anti-static wristband while you are working.
Remove RAM modules if needed.
This is most likely if you are upgrading the present RAM capacity with a larger RAM chip.
Press your fingers on the clips on either side of the chip to pop it out of the socket.
Pull the chip out of the RAM compartment, holding it by the sides of the circuit board rather than on the chip.
Insert the new RAM module into the socket. Align the RAM module so that the notch lines up with the tab on the side of the socket.
Gently lower the module into the socket. Press into place with your fingers.
Replace the RAM compartment cover. Insert the screw and tighten.
Replace the battery and secure with the lock.
Plug the Toshiba Satellite laptop back in and power up the system.
The upgraded RAM should be automatically recognized.
hope this helps
HOW TO INSTALL MEMORY UPGRADE TOSHIBA SATELLITE LAPTOP
not sure if this is the right laptop
http://www.youtube.com/watch?v=RdCzsjDp_lc
