Took mine out of storage to sew a project. The small plastic cover for the bobbin case that slides into the metal case is missing. What is the parts number and where can I get a replacement? (FAST)
Hi, check this site out :
http://www.sewingpartsonline.com/brother-cs6000i-parts.aspx
Regards
.Rob
www.electronicrepairs.co
SOURCE: Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
