Invacare Pronto M41 Power Wheelchair - Color: Red, Seat Type: Semi-recline Van Logo
Posted on Apr 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking wrench light on an invacre pronto m41 power wheelchair, what does this mean?
Want to know what the codes are for the blinking wrench light?
Colin Taylor
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 347 Answers
  • Posted on Apr 22, 2013
Colin Taylor
Expert
Level 2:
Mentor:
Answers
347
Questions
Helped
91230
Points
545
Hello,all the info you seek will be found in:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Download it as a PDF File,36 pages full of info.Page 19 to 36 focuses on what you ask for.I am sure you will be happy with what you see,take care.Colin
Yellow blinking light what does this mean on pronto M41 invacare?
The AMBER service indicator will light when an error or fault occurs. This is a yellow wrench shape. Refer to Diagnostic Codes on page 33 for a listing of the flash codes and what they indicate:
https://www.phc-online.com/v/vspfiles/V4_Backup/docs/MK5-NX_Electronics_Manual.pdf
We put gears on it starts goin then it stops it self
Look at the joystick when the chair stops. The battery level lights should be blinking a certain number of them repeatedly. The lights are a diagnostic code. The number of the battery level lights blinking will tell you if you have a motor, joystick, module or battery problem.
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
A Pronto M41 w/ SureStep was given to my Best Friend who has stage 4 cancer throughout her body. It seem to charge fine but a yellow wrench light comes on. Because it was given to her how can I how and...
Since time was important this may be too late.
1. You can download manuals for pretty much anything by asking Google for something like 'Pronto M41 manual'. Manuals help a lot.
2. Googling 'wheechair repair [your town]' will point you to people who can service the chair. You can also contact a local agency for people with disabilities for ideas.
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
1helpful
The wrench flashes 5 times on the m41
Left parking brake has an issue. Check wiring first then measure brake resistance. Should be under 100 ohms. May also be brake release switch is faulty or brake not engaged.
2answers
Flashing wrench 9 times
Lester - so many issues. Take it to a dealer.
9-Flashes means comm fault - check joystick wiring harness.
1helpful
Wwe have a pronto m41 mobility chair.the service indicator light is telling me its a right brake problem can i fix this and how. also the led lights are chasing left to right. i have to get this working...
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
