I just recently put together a new build. i got the motherboard in and all the wireing is hooked up. when i turn the switch on on the back of the power supply, a light comes on on the motherboard, but when i push the power button on the front of my case, it does nothing. Shouldnt the fan on the power supply at least come o when i turn the wswitch on on he back ogf my power supply. this is my first build and im confused. Any help would be appriciated
thanks
Kindly check the connection from the front power button to the motherboard. The front power button wire may not be plugged into the correct jumper.
if that wire is hooked correctly, remove the memory modules from the system and all other wires from the board , except the power supply connectors to the board and then power it on , check the status of the light on the power button.
if you can provide us with the model number of the motherboard , we would be able to help you better
Thnaks
proton
download the installation manual from the link below
http://download.intel.com/support/mother...
Go to the option installing parts....and follow step by step putting the parts together.
Yes you are correct , RAM chips are called memory modules.
Just for refrence, you can watch the video
http://www.youtube.com/watch?v=rdsUuWlhO...
Thanks
proton
the motherboard is an intel dp35dp. the instructions say to plug the front power button wire to any atx wire from the power supply. By the way whats the memory modual, is that the cpu or the ram
hanks
