Oil sending unit is under intake manifold, just behind the oil filter on the passenger side (difficult to see-use flashlight). Best option to change : Get everything to do an oil change, removal of the filter makes easier access..
Testimonial: "This sending unit was found on the top of motor behind the distributor -----must remove the cap and rotor and distributor to replace it---it takes a 24 metric metric wrench to remove-----this unit also controls the fuel pump on the car so before you change a fuel pump at $300 try this first "
remove the distributor and replace sending unit located behind it---has a plug in and you need an 24 metric wrench to replace it-----this pressure unit if bad will cause your fuel pump to shut down to save the motor if run low on oil as my wife did----if car starts when fuel in poured into carb then this is your problem
