Quasar VV-2002 20 in. TV/VCR Combo Logo
A
Anonymous Posted on Apr 22, 2013
How to get the menu off the screen without remote
How do I tune my teac led/lcd digital tv model no:le32a321 without a remote
Here are some steps to tune a Teac LED/LCD digital TV without a remote:
  1. Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
  2. Use the arrow buttons to navigate to the channel setup or tuning menu
  3. Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
  4. If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
  5. Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
How to access the menu on sanyo dp26648 without remote
You can't without the remote. to buy one go here www.remotes.com or try eBay.
How do I access menu screen without remote controller on my hd30746 Sanyo HD tv
Unfortunately without the remote you cannot access the menu screen
My lglf7700 has the passcode enabled and i have forgotten it how do i do a factory reset please.
Try this...
The following functions are going to vary depending on the LG model that you have, as manufacturer updates are made without consumer notice.
Turn on the TV, press and hold the menu button on the remote and on the TV simultaneously until a menu shows on the screen. That *MAY* be the service menu.
On the bottom of that menu there will be a selection that reads "load defaults." Toggle down to it with the remote, press enter and then exit the menu by pressing the menu button on the remote.
Or try this...
Turn on the TV. Press and hold the menu button on the remote until a 4 digit passcode prompt comes on the screen...should take about 5 seconds. Enter 8741. Another menu *MAY* come on the screen with a selection for loading factory defaults. Toggle down to it with the remote, press enter and then exit the menu by pressing the menu button again.
1helpful
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
2answers
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
3answers
Philips 42pf7320a37 Plasma TV. Menu appears without being requested remotely or manually. Must select Menu Remotely (or manually) to regain screen. Screen stays on for a few seconds or up to 20...
Check that this is not caused from a stuck button, or a defective remote recalling the menu.
If it is not the remote, then you will probably need to replace the control board or the button assembly.
NO REMOTE
I do not think there is a way to get full screen without the remote control.
Here is a link where you can find the remote.
15helpful
2answers
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
2answers
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
