Sony KV-36XBR400 36" TV Logo
Posted on Apr 22, 2013
My sony xbr 400 sounds like its going to turn but no picture red
My tv sounds like its going to turn on when power Burton pushed bit no icture red light bli nks5 timeafter a couple dataa then turba on where or i
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Dec 29, 2007
SOURCE: SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Anonymous
  • 9 Answers
  • Posted on May 12, 2008
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties.
-Dave
Anonymous
  • 4234 Answers
  • Posted on Sep 16, 2008
SOURCE: Sony Trinitron XBR, Stand By Mode?
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Anonymous
  • 252 Answers
  • Posted on Oct 14, 2008
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Anonymous
  • 4 Answers
  • Posted on Feb 17, 2011
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Sony TV XBR-43X800G solarized picture, how to fix
If you're seeing a solarized picture on your Sony TV XBR-43X800G, there are a few things that could be causing the issue. Here's how to fix it. First, check the input source.
If you're using an HDMI cable, try switching to a different input. If you're using a component cable, make sure it's securely connected to the TV.
If the input source isn't the issue, try resetting the TV. To do this, unplug the TV from the power outlet and then plug it back in. Once the TV is back on, go to the Settings menu and select Picture.
Scroll down to Picture Mode and select Standard. If you're still seeing a solarized picture, there may be an issue with the TV itself. In this case, you'll need to contact Sony customer support for assistance.
Sony xbr-49x900f tv has sound but no picture after a min or shorter
Hello
in this case ld board is defective please replace ld board .
thanks
M Nasir
Sony led tv picture black and won't turn on. I've unplugged it. Reset it. Only thing I can get is sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2answers
Sony bravia xbr has red vertical lines going through it
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Sony XBR 40" tube tv.
Failure of the vertical deflection module/circuit. The tv will have to be opened, the vertical deflection circuit found and replaced.
Definitely a job for a pro - the circuit is going to be extremely difficult to extract. The repair will cost you about $200: $20 for a new circuit and $90 per hour for the 2 hour job.
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
2helpful
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
