SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
SOURCE: Repair Manual for TORO 51464 Electric trimmer
Repair manuals aren't available for free download. Owner/operator's manual are though. Most service centers won't even repair electric trimmers, saying that the work is not cost effective.
Here is a link to the closest thing to a repair manual.
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=29830CA7%2DF9A0%2D11DF%2D9262%2D00D0B789305D&&ProcID=9812&ManualID=300&ProductID=-1&Edit=No&Skill=1&Lang=-1
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need opposing force.
