click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
unfortunatley we cant get that drivers but try using this website... www.drivermax.com ... in that isntall the software and this will take care of ur drivers...u can get ur drivers from this site...
Are you trying to record and listen at the same time? It doesn't usually work that way, the computer has to process and encode the audio signals before they can be listened to. Once you restore the computer, are you able to listen to the recording? If you have onboard sound, rather than a separate sound card, all the audio processing is done by your CPU. If you are trying to listen to the audio as it is being recorded, you are probably overloading the capabilities of the device and its shutting itself down. Try to record without listening. Also make sure you have the latest drivers. If it is onboard audio, check the manufacturer's website for updates. If you know that it is Realtek AC 97 (probably says so your manual), you can download new drivers from the Realtek website.
You can find the latest VIA AC 97' Audio driver here: Win XP: http://www.viaarena.com/default.aspx?PageID=2&OSID=1&CatID=1010 Win Vista: http://www.viaarena.com/default.aspx?PageID=2&OSID=36&CatID=2910
If you can tell me what motherboard and windows version you need the drivers for I might be able to be more precise.
Install a copy of Everest or PC Wizard on your PC. This will tell you everything you want to know about the hardware on your computer. When you locate the sound card you can then search the web for the drivers.
go to website VIA technologies.
AC 97 driver is an audio chip driver, for your motherboard.
you,ll probably need motherboard information ( make-model-et,c ) If you just type in AC97 loads will come up. this is asking for a specific driver, for a certain Chipset on your Motherboard.
Mike @ compurepair.
