My printer language needs to be reset
Incorrect language appears on the display If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following: CHANGE THE LANGUAGE USING THE PRINTER MENUS 1 From the printer control panel, press . 2 Press the arrow buttons to scroll to Defaults, and then press . 3 Press the arrow buttons to scroll to Set Defaults, and then press . 4 Press the arrow buttons to scroll to Use Factory, and then press . 5 Complete the initial printer setup. CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE) 1 Turn the printer off. 2 Press and hold down and , and then press to turn the printer on. The printer resets and starts the initial printer setup. 3 Complete the initial printer setup.
Printhead error
SOURCE: Printer Dell Photo All-in-One Printer 926 language
Here's an effective way to change the language on the 926 printer *turn on the printer *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key four (4) times *press the check button *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key until you find "English" *press the check button let me know if it works thanks!
SOURCE: Dell Printer Home is saying "no compatible
Make sure the drivers installed properly, try reinstalling them!
Make sure the drivers are correct for your operating system. To do this go to www.dell.com, and download the proper driver for your Operating System.
SOURCE: how do i shut off my dell v313 wireless printer
It has and on and off power switch. Locate it and push it. Or pull the power cord out of it if you are unable to find the switch.
The power switch is the one in the top left hand corner of the machine with the circle on it. It says "on" right above the circle. Press and hold the button for about 20 seconds or until the machine starts to power down. That will turn it off.
SOURCE: Which driver download (ie number/name)
Click here Click on above link select os and then download drivers and install. Let me know if you need further assistance. Thanks for using FixYa.
Testimonial: "Many thanks for your reply, D/l files now, cheers.."
