I have a similar issue on my Kenmore front loader He washer. I was told by the mfg/repair man that this is "normal" unless you have it on a CONCRETE SLAB, like in your garage!. Even though all the pix on the website and literature on the Kenmore/Sears sites showcase these washers INSIDE the home on shiny wood floors, that is just false advertising since they will SHAKE LIKE CRAZY if you do put it indoors/not on a slab. Had to live with this issue for 8 years now! hate it, have to close the door to the laundry room every time we do laundry to avoid the noise throughout the house! Not a good design at all if you cant have wood Pergo floors as most houses do and install the washer there without having to be unbalanced no matter what.
Try making it level
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: Kenmore HE2 Frontload Washer will Not go into spin cycle
Could be that you have something in the pump. Remove the bottom panel by removing 3 screws and you will see a round cap facing you in the center of the washer at the bottom. there will be alot of excess water behind this cap so get ready with plenty of towels. Unscrew the cap as you would the gas cap on your car and all the water in the lines and in the machine will come out here. Inside here you may find a number of things. Some of the things I have pulled from them are ...coins, socks, pencils, underwear, underwires to bras. The list goes on and on. Or you may not be using "he" detergent. Use only "he" powder detergent. Use vegetable oil to remove excessive sudds build up then use 2 cups of vinegar to clean the machine on whitest whites seting.
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
SOURCE: My Kenmore HE2 Plus codes F24. What does it mean
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor). A bad wiring connection or a failed control board could also cause this problem.
If you have the technical ability to safely access internal washer components, you may be able to repair this problem yourself. Diagnostic steps would involve unplugging the washer and checking the wiring connections between the thermistor and the control board. A resistance check of the thermistor would be needed using a volt/ohm meter.
hope this helps....
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
