The button you push for sound, only works sometime. Can't figure out how to get the bottom off to check the switch.
There are 6 rubber foot pads that under each one is a screw. I had the same problem and we found out that there were screws under the rubber foot pads. Once we were done we glued the rubber foot pads back on the lionel lamp. (Lionel Train Desk Lamp)
SOURCE: I have a Lionel War
From the impact of the train when it hit the ground, it has probably damaged the sound system beyond repair. There are multiple problems that could've occurred, such as the wires breaking/loosening, or the sound box could have broken. There isn't a realistic way to fix this, really.
Even though it may not have been your fault, you should try to prevent things like this from happening in the future.
As to the 042 switches, this is likely the same problem. You can order replacement switches online to test them and make sure for relatively cheap, however.
There is hope for you, however. Go to the link below to go to Lionel's customer service page. There, you can find replacement parts and service stations that can replace/repair your train for you, for a small price compared to the value of the train itself. Good luck getting it fixed!
http://www.lionel.com/CustomerService/
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
