Is not receiving signals from router that is close by does it need to be replaced or is there a fix for this problem?
Is the adapter turned on? Is it getting signals from any other devices? If you need to replace it, it is a really quick and simple process.
Flip the device over and unscrew the cover over it and it will usually have 1 or 2 screws holding the card down. It will be identified by having 2 wires running to it. Unsnap the 2 wires noting how they are plugged into the card now. Take the card out and look at it for a manufacture part number. Buy a replacement card by using that number. Installation is the reverse of this process. No drivers to contend with as it will be the same card. and it will be simple plug and play operation. it should take no more than 5 minutes to remove and reinstall an new card.
SOURCE: Wireless internet connection
You haven't specified if the host computer is able to access the internet. Ip Address confict can be one of the reasons why the laptop isnt able to connect and we can have a series of reasons why we have this IP Address conflict - 1) There is no wireless encryption defined. So, we have neighbors connecting to the wireless network causing IP Address conflicts. 2) The laptop is not able to renew the IP Address after the lease expires. This can mostly be resolved by restarting the computer and in certain cases flusing the TCP/IP stack. 3) There is a static IP Address assigned to the laptop in the router's DHCP range which is conflicting with the host computer. I would suggest you may initiate a chat with me or anyone else who has expertise in routers to get this successfully resolved. That would definitely save your time. Good luck
