SOURCE: engine keeps cutting out
dealer only sorry,unless you can get the software,or better still chat up one of the mechanics
SOURCE: My 2000 nissan maxima check engine light keeps
Tell me what the code or codes are. What fault is the dealer saying.
SOURCE: nissan altima 2000 2.4l p135 and p325 come up ,
I would start with the o2 sensor first if its not working right it will set off the knock sensor but beware of vaccum leaks sounds like your running lean
SOURCE: Engine management light,2000 Nissan Micra
had similar problem, the problem might be the flow meter
SOURCE: 2000 dodge intrepid 3.2 l engine noise and oil light on
Hi! May I ask when was your last engine oil change? Maybe now is the time. When the oil is burnt it makes annoying noise coming from the engine plus a poor performance can be expected. I suggest that you have an oil change and please do check on the radiator fan. If the fan motor is weak it makes the engine hot and run sluggish. Please write back and tell me how it goes. Hope this helps and have a good one!
