Will not boot up. All lights are on and caps lock/num lock lights blink once repeatedly. Have tried hard reset, booting holding F2,F8,F10,F11 etc. Nothing works. Have attached monitor. When I turn on power I hear the fan and drives start but then silence yet all lights stay on.
Have you unplugged, remove battery, plug in, reboot? Try another Cord/Charger with the EXACT same power specs. Has there been any damage to the AC jack due to pulling on the cord while plugged in? Verify your DC voltage at cord plug that fits into the AC laptop jack. Have you reseated/replaced the Memory Mods? The CMOS battery? The HDD ? It sounds like a Power issue as it the Cord/Charger/AC/DC Transformer? Hard to say from here without a MultiMeter to verify. Look at HP support: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3860431
Testimonial: "I bought a new CMOS battery and installed it today... no luck. I guess the CPU is bad according to the blink codes. 1 blink every 1.5 secs. I've held down the arrow keys, all the 'F' buttons and nothing happens.The only thing left is getting some air to blow out the vents and then I'll give up. Thanks for your suggestions."
thanks max... Tried a new cord same thing. I've tried everything on hp's support site.. No dmage at all. Next thing is to reseat/replace what you said but are there any instructions on how to do this?
Here's a video to assist you, try cleaning out the fan, vents, heatsink: http://www.youtube.com/watch?v=4xFM3pvAB... You may want to remove the HDD and test along with reseating/replace the Memory mods and replacing the CMOS battery:http://h10025.www1.hp.com/ewfrf/wc/docum... .
SOURCE: hp pavilion dv5 wont start. the monitor remains
This unit should still be in warranty. If out of the first year warranty, HP has extended the warranty program for Video issues for a extra year from date of purchase.
Register your unit with HP, if not already and email customer care and log your video issue, ASAP.
I hope this has helped you.
SOURCE: HP dv6910 worked fine yesterday; today it will not
you can format your operation system. and in boot drive if you have not sufficient space i mean minimum 20 gb then your pc performance become better before.thanks
