I have some video clips which captured by sony hd camcorders,i want to edit all clips by imovie.
Leawo Video Converter is the best tool to convert video format. You could use Leawo Video Converter to convert m2ts to mov, mov to mp4 and so on. The conversion steps are as described in this article: https://www.leawo.org/tutorial/how-to-convert-mov-to-mp4-with-free-mov-to-mp4-converter.html
Https://geeksrider.com/
To realize MTS/M2TS to MOV conversion, Leawo Video Converter could be your best choice. As a professional Mac based HD video converter, Leawo Video Converter for Mac could perfectly convert HD videos and SD videos between various video formats like MTS, M2TS, MP4, MOV, MKV, FLV, WMV, etc. on Mac OS X, including the latest Mavericks, without quality loss.
MTS and M2TS format is a Sony hd camcorders and Panasonic camcorders format.if you want to edit your video clips by imovie than you have to convert it to imovie suitable format.you can convert it mov format bfor edit.mov format is commonly use and most preferred for imovie.just download a good converter. http://www.aimersoft.com/convert-mts/convert-mts-m2ts-to-mov-mac.html
SOURCE: Video won't import into IMovie
you need firewire to import video, unsure of Imovie software, should not matter once on pc
SOURCE: iMovie capture is poor quality.
hello referring to the SD1 from Panasonic, i recommend to deinterlace the captured clips with "JES Deinterlacer" before editing them with imovie. be careful to use "apple intermediate code" at the output of JES Deinterlacer. i clearly get better results this way, max recommendable size at 1280x720p when exporting QT files... kind regards, bruno
SOURCE: HF10 camcorder cannot read some .mts files
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Remember M2ts files need to be converted to Progressive non HD files so your computer can read them. That will stop the choppy skips.
Hope this helps.
SOURCE: importing clips into imovie mac
convert DVD to MP4 and edit DVD clips in iMovie, DVD Ripper for Mac is a fast application to convert DVD to iMovie accepted video formats: MP4, MOV, DV, 3GP.
SOURCE: cannot display or play ".m2ts" files on Sony PMB
AVCHD Video Converter-a must-have program for Sony, Panasonic, JVC and Hitachi camcorder users to convert the video types: MTS and M2TS movie files. You can get the new video from AVCHD(.mts, .m2ts) to AVI, WMV, MPEG, ASF, VOB, 3GP, RM, RMVB, MKV, FLV, SWF, MOV, MP4, M4V, DV, and extract the audio track from AVCHD to MP3, WAV, WMA, M4A, AIFF files.
