Your heater core is most likely leaking or possibly the hose connecting to the firewall. Bad situation either way as it needs to come out for repair. Might need to remove glove box and associated plastic around the area to get at the heater core. Remove heater hose attached to firewall in engine compartment(2) Will drain water so be careful. To drive vehicle w/o using either heat or cool attach the two hoses you just removed by using a pipe that fits tightly inside them and a screw clamp on both hoses. this will get you by unitl you can fix the core.
