Sony VPL-EX1 Multimedia Projector Logo
A
Anonymous Posted on Apr 20, 2013
Sony EX1 warning (cannot proceed) appears when gain switch is on low or high?
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Jul 12, 2009
SOURCE: Can I connect my computer to my Sony CMT-EX1 CD
stereo headphone jack from pc through to AUX, if on your system, via twp rca plugs
My Sony pmw ex1 cameras view finder and lcd is not working due to my EVF board Wich is on handle is dameged
sir,
Hence it is a prestige model of Sony, the spare parts of this model is available everywhere, can change it easily.
Sony vpl-ex1 doesnt turn on. no light nothihing. power input does work, i can hear it zapping power :). might have dropped from ceiling holder.. atleast it looks like it. im trying to get it work for my...
the filter cover sometimes gets distorted and the small plastic dimple which presses against the switch doesnt activate correctly, check the lamp cover switch also.
2answers
Looking for the UNIT PRISM BLOCK for the Sony PMW EX1
Hola Carlos!
Look at Sony Part Catalog. Enter A1539606A at the top of the page and click Search.
Saudades de Israel,
Pelu.
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
3helpful
2answers
02' Mercury Mountaineer 4WD V8 - High Temp & Low Oil Pressure
I am having the same problem. Changed the pressure switch and that didnt help.
Tv switches source channel without warning
Hi Andy.
What is the samsung model number ?
http://dysonmanuals.llc.nu/
Chris...
Removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
