I can not change any details of my messenger list
I found error code: 40402
SOURCE: error code 40402
[Solution # 1]
You will need to go to your Yahoo! Email Account and delete the contact's name there first.
1. Click Contacts from in the toolboxt to open.
2. Go to the contact you wish to remove and click the box next to it.
3. Go to the top of the list and click the Delete button.
Go to Messenger. When your list of Contacts opens, right click next to the name you wish to remove and select Delete from the drop down menu. The contact will be removed here also.
Error Code 40402 pops up when trying to remove a name while in your Yahoo Instant Messenger list first.
[Solution # 2]
Quit the program, then delete the contents of the “Cache”-folder located here:
c:/program files/Yahoo/Messenger/Cache
That usually solves a lot of problems, that occur all of a sudden. Try that and see if it works
[Solution # 3]
most probably a registry error - if you do not have a registry cleaner try downloading the free version of ccleaner from filehippo
once its downloaded select 'registry' from toolbar on left hand side and run 'scan for issues' followed by 'fix selected errors' if errors are detected
use microsoft 'one care' for further check
Hope they could help you
Good luck
Whenever I try to edit any of my contact details it gives me this error codeĀ "error code 40402"
i cant open chat room and cant delete any address from my address book
when I try to change the name of a person on my contacts list-- i get this error message
i have deleted contacts from address book from email account....but still the deleted contacts come online and goes offline. messenger shows me notice
for eg:-xyz is online now
xyz is offline now
and i cant delete addresses from yahoo messenger...it shows some error code 40402
I am getting the same problem as everyone else, not being able to alter contacts information in my list, every time i get error code 40402??
BAigan ka code error in my contact details
what can i do?
can't change the contact details
i have a problem of error code 40402
when add details in my contact list i get this error code 40402
I can not delete or modification in address book
I am not running Yahoo Mail. Any otherway to delete from Address book with running Yahoo Mail?
