Nortel Meridian M7208 Corded Phone Logo
Posted on Mar 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to use conference button
Meridian M7208 conference calling not working
formulacoop
Level 2:
  • Expert 43 Answers
  • Posted on Mar 11, 2009
formulacoop
Expert
Level 2:
Answers
43
Questions
Helped
30455
Points
138
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Want to change dial pulse out dialling to DTMF tone dialing
unless your phone supports that (and has a little switch somewhere), you just can't. Get another phone, sorry !
Nortel Meridian M7208 page not working...
Press Feature * 3
press the 5th line key you want to use for paging
enter the page-all code (feature 601-603 as you wish)
Meridian phone won't hang up.
Check the handset cable and make sure it is not plugged into the headset port. You should also try picking up the handset while on a call, make sure your HF button is not lit, wait a couple of seconds, then hang up the handset. If that doesn't work, then you should try looking in programming to see if there is a problem there.
1helpful
Meridian M7208. I managed to reset the default
Press feature *3, press the button you want to program back to speed dial, and press feature 0.
Call conferencing
Meridian M7208 Phone-Only 2 lines are working
Sounds like it might be a telco problem. Do lines 3 ,4 work on the other phones?
Switch lines 1 and 3 to see if the problem changes.
2helpful
SCREEN NOT DISPLAYING NUMBERS
If you haven't already tried it, unplug the phone, press a couple of buttons, then plug it back in so it resets. If the boxes still appear, try adjusting the display contrast. Press Feature-*-7 to get to contrast setting and then press 6 or 7 to set mid-range contrast.
3helpful
How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
My phone, a meridian M7208, does not ring incoming calls
following a power failure, the only phone that rings is the one in reception. light still flashes but no ringing from any other phones
2helpful
2answers
Conference Calls/Transfer
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
