Question about Jet 3 Ultra Power Chair
Have a jazzy chair purshased from scotter store. error code flashes 8 times. cant get anyone to come look at it what do i do?
    Sergeant:
  • 317 Answers
If you have a GC Controller 8 flashes indicate a control system fault. Check all connections - especially connections to power module and joystick.
Posted on Jun 08, 2013
SOURCE:
My chair is blinking 4 times and I do not have a manual
If it is a Pride Jazzy or similar, the Diagnostic Flash Codes are in this PDF file.
PDF]INFINFB2048_Jazzy_Select_14_Troubleshooting ... - Pride Mobility www.pridemobility.com/download.php?f=troubleshooting/INFINFB2048_Jazzy...
  1. Cached
  2. Similar
basic troubleshooting instructions for the Jazzy Select 14/14XL power chairs. ... on my Jazzy Select 14/14XL seem to be "dead" (controller does not light up when .... What if the left red battery condition meter LED on the VR2 or VSI is flashing? chair is blinking 4 times Google Search
Nov 15, 2016 | Health & Beauty
I replaced batteries in my jazy power chair, and the control light flashes 9 times.
James,
the flash code for some of the Jazzy's say that your brake solenoid wiring has a problem, check your connections to both sides of the chair. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Nov 19, 2015 | Select Jazzy Used Electric Wheelchair
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
When turned on battery indicator lights flash rather than indicating battery level and chair will not function
The flashes are indicating a problem with the chair. Count the number of flashes and that will tell you the error code and what the problem is ie 4 flashes pause 4 flashes indicate a right motor problem. your users manual should have the error codes in it to explain what each is Hope this helps
Feb 21, 2011 | Pride Mobility Products Jazzy Select
When i turn my chair on the joystick lights are all flashing like when it's plugged in. what does this mean?
The first thing you should do is to narrow down the problem you are experiencing, If the flash code looks like the flash code for the charger plugged in check to verify this at the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
You either have a VSI controller or remote plus joystick with the Jazzy 1103 Ultra.
If you have an off-board charger unplug the charger and turn the chair off and on to clear the error code. If you have an on-board charger that is inhibiting the chair from driving you need to unplug it in the rear electronics area to see if that clears the error. If you have tracked the problem to the charger or charger wiring it is a matter of replacing that component. If you need further help after these initial steps I can provide more specific information if you post again. Hope this helps.
Nov 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My hand controler on my jazzy 1120 2000 keeps blink and I can not get the chair to move the batteries are good
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Oct 05, 2010 | Pride Mobility Products Used Jazzy...
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
Jet 3 Ultra Power Chair Logo
140 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent_G
Vincent_G
ray gallant
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
