The driver should come with the sound card when you purchased it. It should come with a DVD that contains the sound card driver. You can also look for the driver in the website of the sound card manufacturer.
After installing the driver, Make sure to keep it updated so that you can avoid from any issues. You can use RadarSync to automate the updating process in your computer.
David
SOURCE: I need driver of creative sound card 5.1
pls send fujitsu siemens amilo 1505 VGA driver to my e-mail box. my e-mail adress is fm [email protected]
SOURCE: LOST OF SOUND CARD CD OF SB0200 CREATIVE 1.5
http://rapidshare.com/files/210624495/SB_0200_Driver_2.rar
download and install the driver
SOURCE: I need driver sound card Creative Blaster Live!
I found this information, copied it from the Vista Forums, but the post was copied from Creative's site .... so its 3rd hand information, at best!
(from the Creative forums - I just copied/pasted - jh)
For those of you with live 5.1 problems, here you go!! Worked for me!
From the post @ http://neosmart.net/blog/archives/104:
Creative Sound Blaster Live! Series
This applies to all Live! products, including OEM Dell, Gateway, HP,
etc. editions, 24-bit, 5.1, and the rest. Vista 5308 may or may not
find drivers on Windows Update, but even if it does, they will not
support Digital Audio.
1. Grab the ngoHQ modded drivers from
http://www.ngohq.com/home.php?page=Files&a...e&dwn_id=20
2. Run the installer in XP compatibility mode.
3. Restart your computer.
4. In the audio properties in the Control Panel, to enable digital audio go to the Other tab and check digital output.
5. Play with the Format tab to get the audio quality to your liking.
6. You may need to restart to ensure that digital audio works after changing that option.
I'm
not 100% sure if creative is going to be upset that I posted this, but
since they have no plans to support the card in Vista, I can't see a
big problem with it.
BTW, I tried the KX driver and I couldn't get it to work, so for anyone with that problem this should be your solution.
SOURCE: creative audigy 2 CA0102-IAT sound card driver
You may obtain the audigy 2 drivers at:
Audigy 2 Drivers
Thanks for using Fixya.
SOURCE: creative ev1938 driver
http://www.bioticaindia.com/download.php?file=sb-audio-pci-64-ev-1938
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
hope
one of these will help you
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html?tag=api
