Hi, Where can i buy a t-bar for my maxi cosi mura 3 pushchair? I lost just T-bar of my maxi cosi Mura3. regards Ali
Hi
If you are in the UK you can order via your local Maxi Cosi retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 20GBP and if you order direct there is an additional 3.99GBP p+p charge.
If you are not in the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to be sent through to the customer care team in your country who can assist.
SOURCE: I lost my maxi cosi mura 4 hood, where i can find
I would suggest that you contact www.maxi-cosi.com who should be able to point you in the right direction.
I hope this helps.
SOURCE: I have a maxi cosi mura and the hood has broken.
Good evening, I have a Maxi Cosi Loola Stroller and one side of the hood snapped off, how can it be repaired?( I still have all the pieces)
SOURCE: unrepairable inner tube
True Goo inner tube sealant! Go to a bicycle repair shop with your stroller, and honestly, have all the tires shot up with this goo and then pumped up to your desired firmness...
I have a different jogging stroller, but I know the Maxi Cosi's Mura has the same air pump access as other bicycle tires like my jogger does. I kept getting flats, and this goo has kept my tires firm for 6 years now, I used to have to bring along a pump, but never again after this repair, it plugged up a small leak for one of my tires that kept going flat quickly and keeps the others from the eventual softness that was recurring.
SOURCE: How do you fix a flat tyre on a maxi cosi mura?
If you have a puncture and there is only one hole, you can get a puncture repair kit for bikes from somewhere like Halfords and repair the inner tube.
I found the inner tube on one of our tyres was faulty and there were about 20 small holes around the seam. I got a bit fed up with arguing whether or not the guarantee should cover this and so we ended up buying a new inner tube from our local tyre place http://www.etbtyres.co.uk/ it was only £5.
SOURCE: i lost the front bumper bar of a maxicosi foray
You can contact Maxi by email or phone number. I have listed down below.
email address is [email protected] or [email protected] or you can call during regular business hours at 1-800-951-4113.
You should be able to get a replace front bumber bar for you Maxi.
Thank you
