SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
SOURCE: Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
SOURCE: toner mess on one side of paper dell 1720 printer
The transfer roller may have toner on it that is making that mess. Remove the toner and drum, look inside the printer, there is a grey roller towards the back of the printer. Is there toner on the right hand side that corresponds to the print out? If there is, cleaning it may only make it worse. Replacing it would be the best solution. You would want to make sure that the drum is clean after replacing the roller, if it is not ,then it will transfer to this roller once again.
