My suggestion would be to buy a wiring harness and a dash mounting kit. After that unscrew or pull out the console/dash part thats around your factory deck. Then unscrew the bolts/screws holding the factory one in place. Remove it. Plug the wiring harness into the factory wire plug. Pull harness wires through the mounting kit. Attach the corresponding colored wires from the harness to your new deck. Slide your deck into the mounting kit and secure it in place. Most decks have little prongs that you can pry up to **** up against the mounting kit so it wont slide out without pushing those down (makes it more secure and harder to steal). Place deck with mounting kit into area factory deck was. Put the screws/bolts back into place tightly. Place console/dash part back on. You will need the mounting kit (99% of new decks are smaller than the factory). Wiring harness is optional but recommended.
scottmar7- You need the wiring diagram for your panasonic deck,the diagram is as follows.
red- 12volt key switched
yellow-12volt constant-memory
black-ground
white-left front positive
white with black stripe-left front negative
grey- right front positive
grey w/black stripe-right front negative
green-rear left positive
green w/black stripe-rear left negative
purple-right rear positive
purple w/black stripe-right rear negative
blue- remote turn on- for amplifier
These are all the wires you should need,to hook up you deck.
If you need anything else let me know,I can help you,happy listening. cooltek mar,14/08
