I can send faxes with no problem, but when someone tries to send me a fax they get the engaged signal. I have checked all my settings and I believe they are correct. I spoke to Epson technical support which was a waste of time because the person I spoke to would not believe the machine doesn't have a phone!
SOURCE: Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
here's a good place to start..see the user manual at the bottom of this page
SOURCE: Our Epson Sylus CX9400Fax Series is not receiving
Ok, here's a check list for you.
SENDING
Check the following:
Follow these steps to turn off the ECM setting:
RECEIVING
Try the following if you can't receive a fax:
SOURCE: Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
SOURCE: My epson fax machine is hooked to magic jack and
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
