SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
SOURCE: phaser 7400
i have a phaser 7400 printer when i turn on the printer it say cyan led error turn off printer and turn it back on. It keep on giving me this message what should i do. Another thing is that a gear on the waste cartridge is broken is there a way i could fix it without getting a tech to come look at it. It alway say waste toner is full, ( replace it) which i already did. What should i do?
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
SOURCE: Xerox Phaser 7400 displaying error code u60
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
