I have reset the machine, but nothing has happened, the machine status is saying its p21, but this has never happened before, could anyone give any information as to why it is saying this, and how it can be fixed?
SOURCE: Status monitor for Konica Minolta 2400w
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
SOURCE: Minolta Fax 3900 problem at work
I have a Minolta Fax 3900 and it at times while trying to send a fax will say *tx cancel* and only send 2 pages of a fax. It appears like it does send the fax but it might not be the complete fax. I can't cancel the fax or stop it either. Does anyone know how to fix this problem.
SOURCE: my konica minolta magicolor 4650DN laser printer
That's the Image Unit. It should also tell you what color. C, M, Y, K. Cyan, Magenta, Yellow, Black. Image units are seperate from Toner cartridges and don't need to be replaced as often. You will also hear people call it a Drum Unit. That's the same thing.
its a konica c451 btw.
